Good evening, I'am testing the website. Everything went very well. But now my website gives failure messages after clicking items in the menu. Please inform me what I did wrong and how i can fix the problem. See the screenshots to get a good impression of the problems showing up on www.noorderplantsoenondermemersnetwerk.nl. Hopefully someone can help me!!! Looking forward for a solution!
Hello, The website link you have sent is not working, it seems that there is some text missing in the web address. So check the link again and resend to us. So that we can check your issue. Thanks & Regards Gourav Shrivastava
Good morning Gourav, This is the link: http://www.noorderplantsoenondernemersnetwerk.nl. Hopefully you can help me detect the failure and give some tips. So i will be able to fix te problem. The homepage seems to be fine, after clicking an item in the menu or link on the page, failure messages occurs. Looking forward towards a reaction! Chantal
Hello, This issue maybe because of plugin (if installed). So please deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s). This will solve your issue, if not then please provide the following information listed below. Thread Link: http://www.inkthemes.com/community/threads/failure-issues-after-clicking-menu-items.11930/ Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] . We will check and try to resolve your issue.
Hi Piyush, Thanks for your reaction. I deactivated immediately. Unfortunatly the problem wasn't resolved. Have a look the problem keeps appearing. Do you have any other suggestions to solve the problem? I also send a message to support with url/username and password. Thank you en regards Chantal
