Feature Columns Appearance Speed
Discussion in 'ColorWay WordPress Theme' started by 1stopnonprofitshop, Mar 9, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    Can you make the 4 feature columns show up faster? When you first load the website, if you scroll down quickly, they don't appear. Can they appear right when the website loads without scrolling down? I'm just afraid these can be missed because they take a bit of time to appear.
    theme1.1stopnonprofitshop.com
    Please follow the screenshot given below. .
  3. 1stopnonprofitshop
    When you say Comment-our the highlighted section...do you mean remove this?
    "Comment out" means avoid your unwanted code to gets compiled or interpreted in your site.
    Hope it will be clear to you now..:)
  5. 1stopnonprofitshop
    So all I want to take out is animate.css and leave everything else that you highlighted? Sorry...this is new to me and don't want to remove what I shouldn't.
  6. priya
    Please don't get confused... You just all have to do is comment out the red highlighted line by adding // tag at starting of the code as I have mentioned in the screenshot....
    If in case you will feel any trouble, please let us know we are here to help you in all possible ways..
  7. 1stopnonprofitshop
    Do you know why it takes longer for the first 2 images to show up, but the last 2 images show up immediately?
  8. nitin
    nitin Guest
    It seems that you have made some custom changes to your website which is creating the issue and also make sure you have the latest version installed.
    Incase, you still remain with the issue, just send us your website WordPress login details at [email protected] along with the thread link.
    Your Website URL:
    WordPress Username:
    Password :
    We will try to fix the things from our end.
    Nitin
  9. 1stopnonprofitshop
    All I changed is the section that I was told to in order to remove the animation. How do I update to the latest version? What is the latest version?
  10. 1stopnonprofitshop
    I also have a child theme on this site....does that affect how it's updated?
  11. priya
    Here're the steps of updating the theme...
    Download the ColorWay theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder colorway like colorway_new,
    Again, you would need to create a zip file of that renamed folder (say: colorway_new.zip),
    Then, activate your theme,
    And there will be no effect on your child theme after updating the theme...
  12. 1stopnonprofitshop
    On Inkthemes.com, I don't see where it shows what the current version of Colorway is. Where do I find this? I'm not sure if I have the current version or not.
  13. priya
    You will get the updated version from your members area account...
  14. 1stopnonprofitshop
    Right...but where do I see what version I'm currently using and what version is currently available?
  15. priya
    You can check it from changelog.txt file...
  16. 1stopnonprofitshop
    I followed the steps, but it's saying Theme install failed. It says the theme is missing the style.css stylesheet. I looked inside the file, and I see the style.css file, so not sure what is happening.
  17. priya
    Would you please send us your dashboard credentials at [email protected] along with this thread link as well and we will install the theme for you..
  18. 1stopnonprofitshop
    The updated theme was installed and it didn't correct my issue. Website is theme1.1stopnonprofitshop.com and the first 2 columns in the "featured columns" section is still taking longer to load than the last 2. How do I correct this? I tried to optimize the images, but that didn't help. It's obviously not an image issue, as the text under those 2 columns take just as long to load. I'm attaching a snapshot of the issue area. The area circled in red loads slower than the other 2.
  19. priya
    Would you please deactivating all plugins to see if this resolves the problem. If this works, re-activate the plugins one by one until you find the problematic plugin(s).
  20. 1stopnonprofitshop
    I tried that and even when I deactivated all my plugins, it didn't change the loading speed. The first 2 columns are still delayed. Do you think it's something in the coding when I deleted some of the code to not animate this section?
