Featured Listings Section
Discussion in 'GeoCraft WordPress Theme' started by spoonboy90, Jun 28, 2013.
  1. spoonboy90
    spoonboy90 Active Member
    If I have set the Slider Limit to 4 for example when someone trys to add a Featured Listing but their are already 4 in a category then will they be prompted that there is no more room in that category/homepage or will the listing go through and they still get charged?
    Is there a way to remove the Featured Listing section completely just for Category pages but keep it on the Home page?
    Listing will go through and they get charged. No matter there is room in the slider or not.
    But yes you can remove Featured Listing section for Category pages.
    Go to the
    geocrafttheme\library\front_end\
    and remove code as shown in the image.
  3. spoonboy90
    Thanks and how do I go about removing the actual section from the Category page?
  4. Nitesh
    For this Go to the
    Appearance > Editor > taxonomy-listcat.php
    and remove code as shown in the image attached.
  5. spoonboy90
    Also had to remove the 3 lines at the top of the section you highlighted but all is good now
    Thanks Nitesh
