Few problems, please help!
Discussion in 'GeoCraft WordPress Theme' started by karulo, Feb 15, 2013.
  1. karulo
    karulo New Member
    HI,
    I have a few problems with this them, note that it is translated to Spanish.The issue are the following:
    1-In the listing page the lead capture in the sidebar appear way to down.
    http://www.negocios.teinspira.com/publicar-negocio/
    2-Also in the links doesn’t work and the images i didn’t upload appears as upload image (but in Spanish)
    3. not possible to upload images (as an administrator or user). Appear the following error:
    Upload Error: File is empty. Please upload something more substantial. This error could also be caused by uploads being disabled in your php.ini or by post_max_size being defined as smaller than upload_max_filesize in php.ini.
    4-The website look bad in internet explorer but ok in firefox.
    Could please help, thanks in advance!!
    PD: I am not a tecnical guy so I hope there is not any big coding involve.
    Deactivating all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s). It will resolve your issue, If not then please download theme from members area and upload it.
  3. karulo
    karulo New Member
    Hi Nitesh,
    Thanks for your answer. I tried everything you said and is not working, I first disconected the plugings abut this didnt solve the issue, then I deleted the theme and download and reinstall it again. So I still can not uploade any image (same error message appears) and the links are not clickable.
    What else I can do?
  4. Nitesh
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
  5. Nitesh
    We have checked your dashboard.
    Your maximum uploading size is smaller then the image size that we are uploading.
    So please contact to your service provider they will increase your max-uploading size.
    For IE issue.
    We have checked your site on IE at our side, It is looking fine.
    Please make conform that your IE browser is not set to compatibility mode. If it is, Then set it to standard mode. Site will look fine.
