Few questions about Testimonials
Discussion in 'Smartbooking-Appointment Booking WordPress Theme.' started by sangermike, Sep 29, 2014.
  1. sangermike
    sangermike Member
    URL : www.pricechiropractic.org
    How can I deactivate the photos for the Testimonials slide show?
    How can I adjust the speed of the slides?
    Or how can I make it manual scrolling?
    I'm using the plugin Strong Testimonial for a form to generate reviews from clients so I just insert the shortcode for that particular review to link to it in the built in testimonial showing in the front page. The name is duplicated.
    How can I just show one instance of the name scrnshot review.jpg ?
  2. Pramod
    Pramod Guest
    .tst-image{
    .client .name {
    Unfortunately ,Slider speed cannot be changed.
    Pramod
  3. sangermike
    sangermike Member
    how can I center the review after removing the photo?
  4. Pramod
    Pramod Guest
    After removing photo you can center review by this CSS code.
    .tst-text {
    margin-left: 0;
    Pramod
  5. sangermike
    sangermike Member
  6. sangermike
    sangermike Member
    I actually added the codes before then deleted it coz it was not centered. Then I added it again with the new codes for centering. The site still looks unchanged. How can I correct this?
  7. Pramod
    Pramod Guest
    Please use above code to remove image .
    And then use code to center remaining .
    Pramod
  8. Yogesh
    Yogesh Guest
    .tst-image {
    .tst-text {
    margin-left: 0;
    .triangle-arrow2 {
    Yogesh Bhade
  9. sangermike
    sangermike Member
    i was just going to ask about the arrows coz i centered it and removed image already but the border box is cut off because of the arrows. I just added the code you gave for triangle-arrow2 hoping it would correct the issue but it didn't.
  10. sangermike
    sangermike Member
    Ok now I see the change. I dont know why but for some reason, I only see changes when I'm logged on-or after a bit while for changes to kick in. Thank you for your time.
  11. Swapnil123
    Swapnil123 Administrator
    Hello Sangermike,
    Pleased with your response !
    Let me know for further doubts and queries.
    Thanks & Regards,
    Swapnil Gupta,
