Few Sloppy Issues
Discussion in 'GeoCraft WordPress Theme' started by spoonboy90, Jun 28, 2013.
  1. spoonboy90
    spoonboy90 Active Member
    1. I have 'Description' set to display only in premium however a description is still displayed on the small listing previews.
    2. In free listings while the social media icons don't display, if a user has added the links then the 'Social Media:' title is still displayed which looks sloppy.
    3. On the 'Update Listings Form' within the dashboard there is stray description on the address
    4. The 'Description' field description is still not displaying on the New Submission form.
    5. No default text showing in the address box on New Submission form.
    1) It is not possible to remove that short description field from free listings. It will affect premium listings too.
    2, 3, 4) Replace your "single-listing.php" with the file attached.
    5) Default text displaying in the address box on New Submission form. Please check it again.
  3. spoonboy90
    5) What you have higlighted is the description the 'Default Test' should populate the actual address box yes? like in my web address fields!
    try for yourself http://www.stokebusinesslistings.com
