Greetings, I had problem with the theme, particularly when i use Chrome and Opera: On firefox, i see all elements of the homepage but when i use Chrome or Opera, the slider and one block are apparear only on the homepage. I suspect a problem with javascript who is not started on these browsers. I tried replace the theme with the orginial version on fillezilla but anything has changed. Thanks for the help.
Hi, Will you please share your website URL here? Looking forward to hearing from you. Regards, Akbar InkThemes.com
Hi, I have just checked your website and found that you are using the older version of the theme that's why you are facing these errors. So, you are requested to update the theme to the latest version. The latest version of the theme is available on your members account, Just visit your members area: https://www.inkthemes.com/members/member and download the zip file of the theme. Regards! Akbar InkThemes.com
Hello, After delete, add the lastest version of the theme and ctrl+F5 on Chrome and Opera, it works. Thanks of the help.
Hope your issues have been resolved. Just need a quick feedback from your end, Please check below link. https://goo.gl/forms/LNDY7bci4UEsHkG42 Warm Regards! Akbar InkThemes.com
