Figero - Please Help
Discussion in 'Forum Rules' started by jalex860, May 19, 2018.
  1. jalex860
    jalex860 New Member
    I have 3 questions that I hope you can help me with:
    1. How do I completely remove the Homepage Featured Section?
    2. How do I remove the Full Cols Section?
    3. Is there a way to remove the Left Column Side of the Homepage Two Column Section and have the Right Column Side move over to the left and sit across the span of both sections?
    Thanks in advance,
    Joanne
  2. akbar92
    Thanks for reaching to us,
    To remove the Homepage Featured Section, just paste the code given below in Custom CSS section.
    .index-container .feature-index {
    And for (2 & 3):
    Akbar
