Hello again Thank you for your help with my last issues. I have fixed all of those changes I wanted to make. Just a couple more and the site will be complete. www.joswebsitedesign.com 1. On the home page sliders, how can I change the line under the slider heading from pink to black? 2. On all pages, how can I change the lines under the logo (that separates the grey from the purple) from pink to black? Or are these lines able to be removed completely? Thanks Maggie.
Hello, 1. For the first issue, Go to the image directory (Theme directory > image directory) and search for the two images ie slider-strip-black.png and slider-strip-pink.png and then interchange their name with each other. This will solve your issue. 2.For the second issue, For the top border of slider, go to the image directory (Theme directory > image directory) and search for the two images ie top-strip-black.png and top-strip-pink.png and then interchange their name with each other. Similarly, for the bottom border of slider, go to the image directory (Theme directory > image directory) and search for the two images ie strip-line-blcak.png and strip-line-pink.png and then interchange their name with each other. This will solve your issue.
Hey Piyush, I have managed to get all the changes done with the css changes but for some reason am not able to access the custom.js directory to make those changes. Any suggestions?? Thanks Maggie
Hello, Follow the link given below http://www.inkthemes.com/how-to-edit-internal-files-through-ftp/07/ This will solve your issue.
