I tried out the Figero theme and was very impressed. Mostly by the editor with the little blue dots that lets you quickly jump around to the different places where things are changed and configured. I was impressed enough to pay for the Pro version. Much to my surprise, the editor is completely different. What gives? Is there a way to enable the improved editor in Figero Pro? Edit: When testing Figero, I uploaded all the images to my media library. Why can't I pick those images for Figero Pro? It's asking me to re-upload everything. When I select one of the images to upload, it gets stuck uploading for a very long time. My images are optimized and sized correctly so it shouldn't take very long.
Hello, Greeting from InkThemes, In Figero lite theme we are using the default WordPress customizer panel and in the Figero pro theme, we are using the Inkthemes default editor. As in Figero lite theme, we have disabled some of the advanced features of the theme which are present in the pro version of the theme. So the amount which you have paid for the pro version of the theme will definitely worth it. Let me know which are all the images you are facing the problem with to upload. Will you please allow us to check your website dashboard for once? Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will do the rest. Here is the link to theme's documentation, just go through it. https://www.inkthemes.com/doc/figero-wordpress-theme-documentation/ This will help you to customize the theme easily. Let us know if you face any of the issues we are always here to help you. Regards, Akbar InkThemes.com
I was able to work around the problem by viewing my images in the media library, copying the URL, and then pasting it in the required Figero dialog. Clunky, but workable.
Hello, Thanks for getting back to us, That's good that you found the solution for the issue. Let us know If you need further assistance, we are always here to help you. Regards, Akbar InkThemes.com
