I installed a plugin called WP Posts Filter to filter posts on a page by category. The pages in question use the Blog template. For the plugin, I am supposed to enter the code [wppf] to execute the filter on the page. The Blog template doesn't recognize it. The Default template does recognize it and filters the post. How can I get the Blog template to recognize the code so I can filter? Is there an easier way to filter by category?
Thanks for the reply. Your solution might be easier, but it's not applicable for what I need to do. How can I get the Blog template to recognize the code so I can filter?
