1. On the bottom section of the front page where is say blog on the original theme the writting needs to be smaller, 2. and the per witting that comes with the theme is still there how can I remove this, 3 on the gallery page on the info bar all the side bar needs to be gone, (page 2) Thanks www.yeppoonrealestatephotography.com.au
Hello, 1) Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: .feature-blog h2 { font-size: 16px; } 2) It's a default blog post. Create your own posts which will replace the existing one. Or just go to the Dashboard > posts and trash existing post "Hello World". 3) Edit your gallery page and select "template fullwidth" as a page attribute. Check image for reference. Thanks & Regards Nitesh Raghuwanshi
