Fixed Dashboard Links for expired listings...
Discussion in 'GeoCraft WordPress Theme' started by ipotent, Feb 3, 2013.
  1. ipotent
    ipotent Guest
    For anyone who was having issues being able to click the edit or delete buttons on expired listings from Dashboard...the below code is a fix for you.
    You just need to edit lines 188 and 189 of dashboard_functons.php (found in /library/controls/dashboard) to the following:
    Line 188
    <span class="modify"><a href="<?php echo home_url("/dasboard/?page_id=$page_id&action=edit&pid=" . $listing->ID); ?>"><?php echo EDIT; ?></a>&nbsp;|&nbsp;
    Line 189
    <a href="<?php echo home_url("/dasboard/?page_id=$page_id&action=delete&pid=" . $listing->ID); ?>"><?php echo DELETE; ?></a>&nbsp;|&nbsp;<a target="new" href="<?php echo $listing->guid; ?>"><?php echo VIEW; ?></a></span></td>
    Hope this helps. Nitesh, Nareej - I know you two are busy with lots of other fixes...so hope this helps lighten the load!
  2. aliounn
    aliounn Member
    Hi Ipotent,
    I have got this problem today, i still getting multiple emails for listing reactivation (more than a thousand !! ) and tried to delete expire listing from my dashboad with no succès. it's allways redirecting me to the home page.
    I tried to use your code above , but it dont work , i'm redirected to an non-existent URL (domain.com/dasboard/?action=delete&pid=113 ) !!
    I saw that you add /dasboard to the URL but it's not working for me.
