I have a problem with the font on the non-responsive theme This is the link to the responsive version - http://1065617567.1065524876.temp.prositehosting.co.uk and this is the link to the non-responsive version - http://1066274479.1065524876.temp.prositehosting.co.uk/ As you can see (at least i hope you can) there is a difference in the Fonts between the two, I would like the non-responsive theme to be the same as the responsive theme font. Ive added the following line to the non-responsive stylesheet as it wasn't present thinking that it might help but it doesn't Code: @import url(http://fonts.googleapis.com/css?family=Crimson+Text:400,400italic,600,600italic,700,700italic); Perhaps you could direct me to a solution? Many Thanks
Hello, Fonts in both themes are same. But they are looking different because responsive theme contain cufon and non responsive theme not. I think you have removed cufon (js / custom.js) from non responsive theme. If yes then please add it again and if you are not comfortable in doing it then do let me know. I will send you non responsive theme again with cufon.
In the non-responsive theme I have custom.js and cufon-yui.js and the same in the responsive theme but also in the responsive theme I have Helvetica_LT_Std_700.font.js & myriad-pro.cufonfonts.js I have copied both of these extra files into the non-responsive theme but they don't seem to have made any difference. I also replaced the custom.js from the responsive theme to the non responsive as the code for the curfon was different Non- Responsive Code: //cufone replacement Cufon.replace({ fontFamily: 'Myriad Pro Regular', hover: true })('.entry span,h1, .post .date li')('h2')('h3')('h4')('h5')('h6'); //Cufon.replace({ fontFamily: 'Helvetica LT Std', hover: true })('.header_info p'); Responsive Code: //cufone replacement Cufon.replace('h1')('h2')('h3')('h4')('h5')('h6'); I've tried the non-responsive with both sets of the above code.
Hello, Please provide the following information listed below. Thread Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] We will check and resolve your issue
Thanks for the efforts, i've resolved my issues with the responsive theme now so I won't be needing the non-responsive one.
