Footer and Menu
Discussion in 'Elite Pro WordPress Theme' started by bgdrew03, Mar 6, 2015.
  1. bgdrew03
    bgdrew03 Guest
    1. I would like the menu bar to be a red gradient, light to dark, with the text becoming White
    2. I would like the footer background (just the 4 column area) to also be red with white text
    Do you have css code for this? Thank you in advance, you guys rock!
  2. praveen
    praveen Support Staff
    Hi bgdrew03!
    1>
    ul.ddsmoothmenu li {
    background: linear-gradient(to bottom right, rgb(243, 137, 137) , rgb(241, 13, 13)) !important;
    ul.ddsmoothmenu li a {
    color: white !important;
    2>
    .footer-wrapper .footer-top {
    .footer_widget p {
    .footer_widget {
    Praveen
  3. bgdrew03
    bgdrew03 Guest
    You are awesome. Is there a way to extend the menu bar gradient across the content area page? Thank you!
  4. bgdrew03
    bgdrew03 Guest
    1 more thing, I need these circled parts of the footer to have white text also (image attached), thank you
  5. praveen
    Hi bgdrew03!
    1>
    #menu .ddsmoothmenu {
    2>
    .footer-wrapper .footer h4 {
    .footer-wrapper .footer a {
    color: white;
    Praveen
