Footer arrow bullet points and movement removal
Discussion in 'RoadFighter WordPress Theme' started by timhollingworth, Sep 29, 2016.
  1. timhollingworth
    timhollingworth New Member
    Hi
    I have just added an instagram plugin to the footer on my RoadFighter theme but it has added the arrow bullet points to each of the nine thumbnail pictures. I didn't mind so much having the bullet points for the Meta links but I would like to see what it looks like if I remove the bullet point arrows and the sideways movement.
    My website is http://www.cameramanfreelance.co.uk
    Thank you for your help.
    .footer .footer_widget ul li {
        background: none;
    .footer .footer_widget ul li:hover {
        margin-left: 0;
  3. timhollingworth
    Hi Priyanka
    Thank you that works a treat!
    After trying both bits of code I think it now looks better if I just use the first part of the code.
    This leaves the link moving sideways as before but without the bullet arrow.
    Thanks again, I really like the theme RoadFighter
    Tim
  4. Naveen
    You are most welcome :) Tim!
