Hello. I'm having trouble editing the footer color on my site: www.daphneanddave.com. I successfully changed the inner part of it to navy blue but the rest of the footer remains light blue. I'd prefer it just a solid block of navy or two-tone blue straight across. I'm new to wordpress / css editing so the simpler the better. Thank you!
It is not possible to change its color because it is an image not a color, If you want to change it color then, Go to images directory present in your theme directory and replace your image with present footer images or edit it. The name of images is 1. "footer-bg-blue.png" 2. "bottom-cornor-blue.png" 3. "footer-bottom-blue.png" Note:- Use same name for your edited image and remove the current image.
