Footer Color
Discussion in 'BizWay WordPress Theme' started by rdeshazer, Jun 11, 2015.
  1. rdeshazer
    rdeshazer Member
    USA
  2. Sobhagya
    Sobhagya Guest
    Dear User,
    You can resolve it yourself, All you have to do is just go to Dashboard->Appearance->Theme Options->Styling Option->Custom CSS
    field and try to cut paste the given below CSS code there .
    .footer_bottom {
      background: #f9f9f9 !important;
    h1 {
      text-align: center;
    Hope that helped.
  3. rdeshazer
    rdeshazer Member
    USA
    for number 1 i'm referring to the menu background color which is forest green, need the color code for the footer background to match.
  4. Sobhagya
    Sobhagya Guest
    Hope Doing Good,
    field and try to cut paste the given below CSS code there.
    .footer_bottom {
      background: #447E11 !important;
