Footer CSS Questions
Discussion in 'GeoCraft WordPress Theme' started by webunet, Jun 10, 2014.
  1. webunet
    webunet Member
    Kalispell, Montana
    Please see attached image. How do I change the footer dashed line to solid & change the color? Also how do I change the color of the LI discs?
    Thank you,
    Tom
    Paste this code in Custom CSS
    Geocraft Settings> Theme Option > Styling Option > Custom CSS
    .footer_wrapper .footer_widget h5 {
    background: none;
    border-bottom: 1px solid red;
    2.
    Go to css > color > images present in your theme directory and replace your image with present bullet image or edit it.
    The name of image is "fbbullet.png"
    Gourav Shrivastava
  3. webunet
    webunet Member
    Kalispell, Montana
    Thank you, but that didn't fix the problem totally (see image attached). The solid line appears, but the dashed line is also still visible.
    Secondly, what is the CSS code to make the footer widget headlines black?
    Thanks again,
    Tom
  4. Gourav
    Geocraft Settings > Theme Option > Styling Option > Custom CSS
    background: none!important;
    color:black;
    Gourav Shrivastava
  5. webunet
    webunet Member
    Kalispell, Montana
    Gourav,
    You saved the day again. Thank you,
    Tom
