Footer issues
Discussion in 'ButterBelly WordPress Theme' started by mckinlt, Aug 27, 2015.
  1. mckinlt
    mckinlt Member
    Hi!
    www.novamidwife.org
    How do I get rid of the roadmap of all of my web site at the very bottom?
    Sorry, we didn't get your issue related to the roadmap.
    Could you explain with the screenshots of that particular area so that we can better assist you?
    Inkthemes.com
  3. mckinlt
    mckinlt Member
    All of the links on the right side - how do I get them removed? Much thanks.
  4. praveen
    praveen Support Staff
    Thanks for the screenshot...
    ul.footer_nav {
        display: none !important;
    Regards!
    Praveen
  5. mckinlt
    mckinlt Member
    thank you. It did not get rid of the links.
  6. nitin
    nitin Guest
    It would be our pleasure to assist you. It requires some customization in the source code of the theme.
    We will do it for you.
    Nitin
  7. mckinlt
    mckinlt Member
    I was emailed this code:
    ul.footer_nav {
    It did not work. Please advise. Thank you, Tammi
  8. nitin
    nitin Guest
    We have made the changes as per your requirements (using the credentials provided earlier).
    Kindly check and reply.
    Nitin
  9. mckinlt
    mckinlt Member
    Perfect. Thank you so much. Tammi
