I have created a new site and in the theme options have used the footer setting to add wording and html code href back to my main site. When I make changes to other parts of the site then save the site part of the footer dissapears from view and when I look in the theme options -footer- it has been removed. This is a bug that I need fixing before the site goes live which is in about 72hrs Please help
Hello, Please provide us your website url as well as the screenshot where you facing the problem. Thanks & Regards Yogesh Bhade
Hello, We checked your issue in our theme, but it is working fine. I think you pressed reset setting button. Please reinstall your theme. That will resolve your issue. Thanks & Regards Yogesh Bhade
What do you mean reset setting button, this dissapears everytime I make any change on the site and click save changes. I don't even know where the reset button is? so you are telling me to delete the theme and then reinstall it?
Hello, Yes you have to delete theme and then reinstall it. That will resolve your issue. Thanks & Regards Yogesh Bhade
Just as I thought, this did not work, I deleted the theme, downloaded a fresh copy from your site and the problem is stil there, please investigate the problem as this site is now late going live
Hello, We can't see your site because it ask for Username & Password which we don't have. Please make your site live without password so that we can see your problems. Thanks & Regards Yogesh Bhade
Really! I don't think so. The site is not live because it's not complete and you want me to put it live ( that's not going to happen) How about you email me and I send you the login details for you to view the site
Hello, Please send login details on [email protected]. We will check your site why the problem is occurring. That will resolve your issue. Thanks & Regards Yogesh Bhade
I haven't heard back from you so I have gone in and hard coded this footer link as the site had to go live.
Hello, Use following CSS in Custom CSS to show footer link content. Code: .footer .copyright { color: #918940 !important; } In place of #918940 please use different color. That will resolve your issue. Thanks & Regards Yogesh Bhade
Why is the actual link not visible? You can see the wording on either side but you can't see the actual anchor text?
Hello, Text color and background color was same so the text and links was not visible. Thanks & Regards Yogesh Bhade
Hello, To change color of footer link(local seo) use following css code in Custom CSS. Code: .footer .copyright a { color: #222222; } That will resolve your issue. Thanks & Regards Yogesh Bhade
