Footer Menu
Discussion in 'Appointway WordPress Theme' started by dlman1999, May 9, 2014.
  1. dlman1999
    dlman1999 Guest
    How do I add a footer menu?
    Go to
    Appearance > Menus
    Create a custom menu and only add the pages that you want to show in the navigation bar.
    Now,
    Go to
    Appearance > Widget
    Drag Custom Menu widgets and select your menu from its option and drop it in the first widget area.
    Gourav Shrivastava
  3. dlman1999
    dlman1999 Guest
    This worked as well!
    Great job!!!!!
