Hi All I have a footer menu which is great but i want to reduce the space between each line. I expect that it is linked to this set of tags .footer .footer_widget ul li { But if you look at the URL below there is to much white space as i call it. i do not want the space between each line. https://pawsandclaw.co.uk/
Hello, Thanks for contacting InkThemes, To make the desired changes, just paste the code in the Additional CSS section of the theme. Go to (Dashboard -> Appearance -> Customize -> Additional CSS). Code: .footer .footer_widget ul li { padding: 0px 0; } Regards, Shemaela InkThemes.com
