Footer Mods
Discussion in 'Elite Pro WordPress Theme' started by spoonboy90, Aug 9, 2013.
  1. spoonboy90
    spoonboy90 Active Member
    1. Do you have a handy bit of CSS to remove the 'Widget' area of the footer but keep the copyright part?
    2. Is it possible to merge the 4 widget areas into 1 area?
    1.For your first issue
    Paste this code in Custom CSS
    .footer-wrapper .footer {
    2.Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry.
  3. spoonboy90
    Perfect thanks Gourav
