Footer & Right hand column on default template page
Discussion in 'Photomaker WordPress Theme' started by proele, Jun 4, 2014.
  1. proele
    proele Member
    Footer & Right hand (not front page) column on default template page , is it an option?
    Footer on main page and other pages would be helpful.
    Right hand column on default template page for banners ads etc.
    You can add widgets for right sidebar. Theme design don't support footer widget.
    If you want different widgets on different pages then you can use "Dynamic widget" plugin.
    Download link.
    https://wordpress.org/plugins/dynamic-widgets/
    Nitesh Raghuwanshi
  3. proele
    proele Member
    Thank you for the info, I am unable to make the "Dynamic Widgets" plug in produce anything on a page, the space for a side bar is there on the default page but nothing appears.
