Footer Text
Discussion in 'Traffica WordPress Theme' started by garfie, Jan 31, 2018.
  1. garfie
    garfie Member
    InkThemes>Footer Setting>Footer Text
    How can I make this text inside of this box go all the way across the bottom of the page in the desktop view?
    Thank you!
  2. akbar92
    Thanks for contacting us,
    Will you please elaborate your query a bit more with the help of edited screenshot?
    So that we can deliver you an exact and appropriate solution to you.
    Akbar
  3. garfie
    garfie Member
    *** Solved ***
    To recap this issue: The Traffica Pro theme at the very bottom of each page on the left side is the "Footer Text". This text is filled in by selecting InkThemes > Footer Setting > Footer Text. Since I am not using the built in Social Media icons on the right side of the very bottom of the theme, I wanted my copyright notice to go all the way across the bottom, not just half way. Akbar was able to log in my site and modify the code in the "footer.php" file. My copyright notice now goes all the way across the bottom of the page. Thanks Akbar! Great job!
  4. akbar92
