Footer Text
Discussion in 'Andrina WordPress Theme' started by dcarels, Dec 9, 2012.
  1. dcarels
    dcarels New Member
    When I was using the trial version of the theme, I was able to put the following within the Footer text within the Theme Settings.
    iViu Technologies Inc. 2012 © All rights reserved | <a href="http://iviutech.com/terms-of-service/">Terms of Service</a> | <a href="http://iviutech.com/privacy-policy/">Privacy Policy</a>
    In the purchased version, it cuts it off after the first |
    How can I fix this?
    Thanks.
  2. dcarels
    dcarels New Member
    I noticed that every time I change the theme options, it will cut this html short. Is there a way to fix this?
  3. Gourav
    Please share the link of your website.
  4. dcarels
    dcarels New Member
    I figured out that it is probably a bug in the theme. To fix, it has to be the last thing I update prior to saving the Theme Options. So my website will look like it works. It's a bit of a hassle, but it works. I'm not sure how to report bugs, but this is definitely one.
