at the site at the site http://macadamiaoils.com/ (site access pw = jindilli ) I have placed an image in the 4 footer area - however it is not displaying in the correct area I have even tried to put blank text widgets in to make it go across to the right - but nothing seems to work ALSO and I would actually like it it line up with the top of the other footer widgets titles so that it looks balanced I tried to put the html in the widget title but that did not work either
Hello, Greetings from InkThemes! I have done the same things as in your footer widget and it works perfectly at our end.. You can also check it in the screenshot given below.. So, would you please deactivating all plugins to see if this resolves the problem. If this works, re-activate the plugins one by one until you find the problematic plugin(s). Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
hi - that is exactly how I would like it to position however I turned off all 6 plug-in and the problem still exists I have sent log-in info to support@
Ok..Smarta Thanks for the details.. We will get back to you soon.. Thanks & Regards! Priyanka InkThemes.com
you have fixed the footer position but now the menu overlaps at the top at wide screen & also at small screen size(see attached) it was working fine previously also logo is not scaling for mobile version
Hello, I have done the changes.. Kindly check your site and acknowledge the same... Thanks & Regards! Priyanka InkThemes.com
