Footer widgets on Nutrition Theme
Discussion in 'Nutrition WordPress Theme' started by lbrudycook, Apr 17, 2013.
  1. lbrudycook
    lbrudycook Guest
    Hi there,
    Two questions:
    (1) I can't drag and remove any of the footer widgets...they just won't move when I try to drag them. Can you help with this?
    (2) May I please have CSS to alter the font for the contact information in the upper right hand corner of the home page?
    Thank you very much for your help.
    1)Go to Appearance > widgets and drop down "screen option" and then click "Disable accessibility mode".
    Check image for reference.
    Paste this code in Custom CSS
    .header .header_info p {
    font-family: your font type;
  3. lbrudycook
    lbrudycook Guest
    Thanks Nitesh. For the footer widgets, the setting was already disabled. I tried to enable and disable again, to see if that would do anything, but it is still not working. I just can't move those widgets.
  4. Gourav
    This issue maybe because of plugin (if installed). So please deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin, This will solve your issue.
    If not then,
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
  5. lbrudycook
    lbrudycook Guest
    Thank you Gourav. I tried deactivating the plugins without success. I have sent the details to support, as you've noted.
  6. lbrudycook
    lbrudycook Guest
    Thank you for your email support. This issue is now resolved. Thank you for your wonderful help, as always.
