Footer Widgets
Discussion in 'Poloray WordPress Theme' started by jonnyc84, Jun 26, 2014.
  1. jonnyc84
    jonnyc84 New Member
    How do I remove the footer widgets that are by default there? I want to leave the footer so I can add widgets at a later point. I just don't want the default widgets showing. Thanks
    Go to the Appearance > Widgets panel in your dashboard and remove all widgets first from the Footer Widget Area and then
    drag & drop empty Text Widget in all the Footer Widget Area.
    This will remove all the default widget from the footer.
  3. jonnyc84
    jonnyc84 New Member
    Thanks. that was so simple I feel ridiculous for asking. :)
