Footer Widgets
Discussion in 'Traffica WordPress Theme' started by garfie, Feb 8, 2019.
  1. garfie
    garfie Member
    Is it possible to change the appearance of the "footer widgets" on smartphones?
    Examples:
    Current mobile display
    widget1
    widget2
    widget3
    widget4
    I was hoping for this
    widget 1 widget 2
    widget 3 widget 4
    I only want this for phones. Tablets and larger would get the default view.
    Thank you!
  2. akbar92
    Greeting from InkThemes,
    We will do it for you and follow you up there using the Emails.
    As I checked it looks like you have changed the login details of your website.
    So, Kindly send the below-mentioned credential details at [email protected] along with the thread link.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do the rest.
    Akbar
  3. garfie
    garfie Member
    Akbar,
    Email was just sent. Thank you again!
  4. akbar92
    Yes, we have received the request from your end.
    We will get back to you soon via Email.
    So, I request you be patient until we are done with it.
    Akbar
