Footer Widgits
Discussion in 'BlackBird WordPress Theme' started by greenknight4, Nov 26, 2014.
  1. greenknight4
    greenknight4 New Member
    I can't get the three footer widgets to spread out evenly across the bottom of the page. The center and right nest to the right and there is a large gap between the first and the second.
  2. Yogesh
    Yogesh Guest
    The first footer area has half width of whole page, and other half width area is divided between second and third footer widget.
    So first footer widget area has more area so there is large space between first and second footer widget.
    You can use any widget that has large content in first footer widget area so that spacing problem will not generate.
    It will resolve your issue.
    Yogesh Bhade
