Hi, The items in the primary widget area appear under any page contact in Chrome. In firefox they appear on the right of the page as they should. How is the best way to fix this? Thanks James
Hello, Greetings from InkThemes! Could you please provide us 'URL' of your site along with some edited screenshot so that we can better assist you? If you are unable to create screenshots then you can use www.screenpresso.com that will help you to create screenshots. Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
Hi, sure. I now think it is a problem. If you look at the pages: http://www.1am.com.au/ and make the width as small as possible so still can see the three icons across the page "Search Blog", "Cars Cars Cars", "Contact" then click on cars / go to http://www.1am.com.au/cars/ You see the the contact form is under the text. If you reduce the width of the browser it then goes to the right of the text like it should. But then if you click on "home" the icons are under each other. Thanks James
Hi Another issue is on http://www.1am.com.au/ where the Feature Image images are; eg Search Blog, Cars Cars Cars, Contact" The words link ok, but the icons dont link... I think they should ? Thanks James
Hello James, Greetings from InkThemes! We have checked your first issue and would like to inform you that we didn't get any issue as you have stated above... Regarding you second issue, i.e. The words link ok, but the icons dont link... I think they should ? So you can easily do this yourself, you just need to follow the screenshot given below. Note: mention your desired link in the code instead of "http://www.google.com" For your information, I am using "WP-Editor" plugin to edit files. You can also download and use it from the link https://wordpress.org/plugins/wp-editor/. After activating this plugin, you will get the same screen as shown in the screenshot. Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
