frame picture lead capture
Discussion in 'Local Business WordPress Theme' started by mirjam, Feb 2, 2013.
  1. mirjam
    mirjam New Member
    I've got following answer from your stuff: But now I can't find where is the images directory/theme directory / present frame image.
    Could you please help me again with this to find it? Thank you so much!
    It is not possible to change its frame color because it is a image, If you want to change its color then go to images directory present in your theme directory and replace your image with present frame image or edit it.
    The name of image is "signupimgshadow.png"
    Now,
    Paste this code in Custom CSS
    You will not get images directory in your dashboard.
    You can find the images directory through FTP.
    Open your Theme directory (through FTP) > images folder > signupimgshadow.png
    Download the file from there, replace your image, Then again upload it at the same place with the same name.
    Thanks.
  3. mirjam
    mirjam New Member
    O.k. now I understand! Great! Thanks a lot! Awesome support!
