Free listings not limited and photos not unlimited
Discussion in 'GeoCraft WordPress Theme' started by langman82, May 7, 2013.
  1. langman82
    langman82 New Member
    My free listings are displaying the same amount of info as paid listings but I have limited the free listings in the admin area. They are not checked in the theme options area and shouldn't be displayed for free listings.
    Also, I created 15 photo areas for paid listings, but it's limited to only 6 photos. Is there a way around this? I would like for my paid listers to be able to display much more than free listers.
    The website is http://www.toptrainerfinder.com and I HAVE ALREADY DEACTIVATED ALL PLUGINS TO SEE IF THE PROBLEM WAS FROM THERE.
    Thank you.
    Go to the
    Geocraft settings > Custom fields and click reset button from there.
    You need to set your custom fields again after resetting them, but it will resolve your problem.
    Note: Before resetting fields open custom fields in a separate tab just for backup.
  3. langman82
    I will give it a try. Thank you.
  4. langman82
    I spent over an hour doing this and now it's worse. My free listings should only show a few fields and the paid listings should show all the fields.
    This theme seems broken at the moment. I made an entire listing with a free account and it should not have displayed the fields unless I paid for it. Please help asap.
  5. Nitesh
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    We will check and resolve your issue
  6. amontoya9
    amontoya9 Guest
    Is there a way for paid listing to have the option of displaying more pictures than non paid listings?
  7. Gourav
    It is not possible to do so, But another method to achieve this is to decrease the numbers of the images from non-paid listing, If you want to do so then go to
    Geocraft Settings > Custom Fields > Select Image and click the edit option of it and uncheck free listing from image option.
    Sending image for reference
    The first image will show in both paid and non paid listing, But you can decrease the numbers of extra 4 images from non-paid listing by using the same process for others also.
  8. amontoya9
    amontoya9 Guest
    Thank you. Well that is unfortunate as pictures are what sells especially for my hotel directory! I need to display more pictures. Yikes!
