Hello, I had too big free space after the text in sub menu tabs. I could center the text with: #menu .ddsmoothmenu li li a { text-align: center; } 1. But now I have still too big equal free spaces for and after the text. How can I resolve this? 2. Can I center the sub menu tabs under the appropriate menu items? Thank you!
Hello, You can paste the following code in your Custom CSS (Appearance -> Theme Options -> Styling Options -> Custom CSS) Code: #menu .ddsmoothmenu li li a { text-align: center; width:auto; padding: 7px; } You can adjust the value of padding as per your requirement. I think this will solve your issue.
Hi, 1. was fixed 2. didn't change: the width:auto; line breaks only two words in two rows. Example: if the sub menu is "first menu" it breaks in: "first menu" Thank you!
Hello, Paste the following code in your Custom CSS (Appearance -> Theme Options -> Styling Options -> Custom CSS) instead of the privious given code. Code: #menu .ddsmoothmenu li li a { text-align: center; width: 115px; padding: 7px; } You can adjust the value of width as per your requirement. This will solve your issue.
