Front page adjusments
Discussion in 'Harrington- A WordPress Business Theme.' started by chetdavis, Feb 10, 2016.
  1. chetdavis
    chetdavis New Member
    I am really enjoying the Harrington Theme at http://chetdavis.com
    - just have theses questions/desires:
    1. Bottom of front page how to update the address that came with the theme
    2. Would like to move the Search bar to under the 'Search Anything' column
    3. Would like to remove the Latest posts column and list
    Thank you!
    Chet Davis
    Hello Chet,
    Solutions of your above issues are accordingly...
    1) Bottom of front page how to update the address that came with the theme
    2) Would like to move the Search bar to under the 'Search Anything' column
    3) Would like to remove the Latest posts column and list
    For this screenshot is given below..
    Overall, you can edit footer information from widget field of your dashboard...
  3. chetdavis
    Thanks so much for your prompt reply and clear tips Priyanka .
    Will work on this today.
    Regards, Chet
    You're welcome Chet...:)
    Hope you will get your issue resolved soon...
