Hi all, I've been using the colorway Theme on our site for a while now: http://www.edinburghreds.co.uk/ In recent weeks the homepage slider doesnt seem to be working. I've not changed anything on the site so can't understand why this has happened. Does anyone have any ideas or suggestions on how to fix this? Thanks
Hello, It's a plugin issue. Please deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s). Thanks & Regards Nitesh Raghuwanshi
Hi, I've tried de-activating all plugins and re-loading the site. The slider still isnt working. I've inspected the code and the console says it can't seem to find the following JS file http://www.edinburghreds.co.uk/wp-content/themes/colorwaytheme/js/jquery.flexslider-min.js?ver=3.9.1 I've downloaded the latest version of the theme and this file isnt' included in the js folder there either. I'll try to upload the latest version of the theme as I seem to be on v 3.0 to see if that helps fix the issue.
Hello, Latest version of theme is Version: 3.2.6. I think you have uploaded wrong wrong version. Access your members area and download latest version. It will resolve this problem. Thanks & Regards Nitesh Raghuwanshi
The actual issue is there are multiple versions of jquery and they are conflicting. Check your page source code and do a search on jquery.js I had the same issue.
One last thing to try as well. You may have a plugin that conflicts with the theme. (i.e. WP Fluid images)
