Front page layout
Discussion in 'Compass WordPress Theme' started by smarta, May 19, 2021.
  1. smarta
    smarta Member
    hi
    I want to change the front page so that the text area goes full width and replaces the Blog section
    I've done it before with this site http://amarco-iluka.com.au/ but don't remember how I did it!
    I think you guys made some changes for me last time.
    I want to change this site http://evansexcavations.com.au/wp/ to the same layout
    I just want to drop an image to appear under the 3 feature panels
    <img src="http://evansexcavations.com.au/wp/w.../front-page-bottom-images.jpeg?bwg=1608776835" alt="" vertical-align="top" align="centre"/>
    I have emailed log-in info to [email protected]
  2. shemaela21
    shemaela21 Guest Staff Member
    Warm Wishes From InkThemes,
    Thanks for sharing the details with us.
    We have emailed you the desired information kindly once check your email.
    Shemaela
  3. smarta
    smarta Member
    the following email reply has been sent with screenshot
    Hello Shemaela
    I have renewed my support
    attached is a screen shot
    you will see that Amarco has text & image section under the 3 feature panels - your support team did this for me
    On the Evans Excavations site I would like this to be the same layout but instead of the text & image - I just wn at this image to appear there
    On the Amarco site it appears the html code for the text image section is entered in the Theme Options in the Testimonials Description area (this enables me to edit it when needed)
    I have set up the Amaraco site login with the same credentials as the evans
    both LOGIN sent in email
    ...also if possible can you tell me what you do to get this too work so I cn do it myself again next time I need to edit a site this way
  4. shemaela21
    Hello Brett,
    I am glad to inform you that we have successfully uploaded the updated version of the theme on your website.
    We have also customized the theme as you wanted us to customize kindly once review your website https://amarco-iluka.com.au and let us know about the changes done.
    I would also like to inform you that we are unable to upload the zip file of the theme on this website of yours http://evansexcavations.com.au/wp,
    since the max file upload size is exceeded kindly increase the memory size so that we can upload the zip of the updated theme for you.
    Shemaela
