I was trying trying to insert a php into the Front-Page.php when I tried to undo it the home page vanished. Please help. And could you explained what I did wrong and the fix? The site is: Evolutionspeed.net
Hello, I have checked your dashboard and find that you have accidently removed all php code from front-page.php which caused the issue. Now, I have fixed your issue Note:- Please don't share your credentials in the thread because this is a public forum, that means any one can use your credentials and misuse it. So, next time please send us credentials at [email protected]. For security reason, I am going your credential details from the thread link. Hope you don't mind. Thanks, Praveen
Thank you. Also could you explain when I opened that particular file (Front-page.php) no code was there. I even checked it on a test site I have and same place no code is there is this something new with wordpress 4.2.2 or with the theme itself? Thank for your help and resources.
Hi, In simple editor available in the dashboard don't have "undo" property that means if you have edited any file and update it once, you will not able "undo" the changes( go back to original state just before changes ). So, I would like to recommend you to use "WP-Editor" plugin to edit files. You can download and use it from the link https://wordpress.org/plugins/wp-editor/. After activating this plugin, you will get "Theme Editor" instead of "Editor" in your dashboard and also able to undo the changes made in the files. Thanks, Praveen
