Front Page Static Page
Discussion in 'Blackriders WordPress Theme' started by onmark lee, Jan 6, 2014.
  1. onmark lee
    onmark lee Member
    Hi All,
    How can I putting a static page on front page instead of put in a blog post?
    What can I do it?
    Lee
    If you are trying to set another page in place of default front page then follow the steps given below.
    1. Create your static home page from Pages > Add New panel of dashboard.
    2. Go to the Appearance >Theme Options > General Settings panel and turned off your front page.
    3. Go to Reading Settings panel (Settings > Reading) and select your static page as a front page from there.
  3. onmark lee
    onmark lee Member
    Hi Piyush,
    It did not solve my problem.
    Actually I wish to remain the slider, lead form, fb widget and front page features.
    and only switch the blog post to become a static just on the right handside of fb widget.
    I did exactly what you asked to do and It did not work.
    When I turned off the front page, slider, fb widget, features all disappear.
    What should I do?
  4. Piyush
    Download the "front-page.php' file attached with this post and replace it with your current front-page.php file present in your theme directory.
    I hope this will solve your issue.
  5. onmark lee
    onmark lee Member
    Any more easier method like put in the code on custom CSS?
  6. onmark lee
    onmark lee Member
    Because in case I would like to enable the original front page.php...
    What do you recommend to do fix it? :(
  7. onmark lee
    onmark lee Member
    Hi Support...
    Any updates?
  8. Piyush
    Create backup for previous front-page.php and save it in your system.
    If you want to enable the original one than replace the customized front-page.php with this file.
  9. onmark lee
    onmark lee Member
    HI Piyush, I have attached the front-page.php to the file manager under themefolder. But I do not think it solved my problem.
    and i have deleted original front-page.php to back up it to my hard drive.
    Pls visit www.weddingliquors.com
    Looking forward to hear from you.
  10. onmark lee
    onmark lee Member
    What I wish:
    1. The front page blog post area become a selective page
    2. remain the fb widget box on right handside.
  11. Piyush
  12. onmark lee
    onmark lee Member
    Pls refer to below screenshot with description...
  13. Piyush
    Firstly edit original front-page.php file of theme by pasting the code given below in that file as instructed in the image given below
    <p class="static_area"> Enter your text here </p>
    And then remove the previous customized front-page.php file and activate the original front-page.php file in the theme through FTP.
  14. onmark lee
    onmark lee Member
    Hi Piyush,
    What i did:
    1. Delete the customized front page php that you have send me
    2. upload the original fron page php on FTP
    3. edit the code on appearance>> editor>> front page
    So how can you select the page that I wanna show in front page as a static page?
    I have selected a page from setting>> reading >> static page >> sample page...
    But nothing comes out on front page.
    If you asking me to add in the article on editor, it would be a headache for me actually.. :(
    However, the fb box on right hand side did not shows up even I have put in the fb page address on howe widget.
    Pls advice. :)
  15. onmark lee
    onmark lee Member
  16. onmark lee
    onmark lee Member
    Hi Support,
    Any update here? Pls advise...:(
  17. Nitesh
    Reading setting static page will not work here. You need to add your static content in the "front-page.php" file. At the place shown in the image attached.
    Nitesh Raghuwanshi
  18. onmark lee
    onmark lee Member
    Hi Nitesh,
    Can you guide me how to make it work? :)
  19. onmark lee
    onmark lee Member
    Anyone else can help me? I lost~~!
  20. onmark lee
    onmark lee Member
    except, manually put in the text on home page. Do you have any other method which i can easily just select the page that I want to be in front page?
    Because if by doing manually edit the front.php, it would be difficult for mr to hyperlink the text or put in the photo as well. Pls understand.
