I have used colorway for years and not updated anything in the theme for a long time. I went to look at my site today, and it reverted to a blog on the front page, but the normal gorgeous theme with the slider, services, testimonials, etc. is gone. Is that only available with the pro theme? I can not for the life of me remember if I was using the free theme or had paid at one point and the subscription ran out. In any event, I need to get my functional homepage back. I purchased pro, but I don't want to overwrite all my info. When I look in the customize area, every bit of verbiage I used to have is still there... I just have a blog on the front page and I can't my original home page back. Also, note, there never was a static home page, there was always the original theme functions and I never changed it. Hope that makes sense! HELP
Hi, Greeting from InkThemes, We need WordPress admin credentials to figure out the issue. Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will try to fix your issue. Regards, Akbar InkThemes.com
Hello, I´ve got a similar problem, but I changed a WordPress Theme to Colorway Pro and do not find the slider homepage, just a blog page or a static homepage. My Page is not finished yet so it wouldn´t be a problem to delete and reset it. Do I have to reinstall wordpress or is there any other way to "reset" that theme? kind regards Thomas
Hello, Thanks for contacting us, It seems like you have set your website homepage as A Static Page that's why slider and other content are not displaying. So, you are requested to set the homepage as Your Latest Post option, Go to (Dashboard->Settings->Reading), Please have a look at the attached screenshot. Hope you find the above information worthwhile for you. Regards, Akbar InkThemes.com
Hi, i have a similar problem. Just updated the theme, and have to set up the homepage....but: there is no homepage...in the customizer i set up all: the slider content, the 4 featured areas...but nothing is displayed? How can i edit and SEE the homepage? Just investet 79 $ and i am very disappointed...:-(...before everything was fine..... I tried the solution mentioned above, to set the blog as homepage - but nothing changed. there is no homepage, i can see or edit. Please help Thanks, regards
Just found the problem: had to create a new page and select template "home page". But it cannot set up the page like it was before: i need 3 slides, and can set up 2 only. I just reverted to the not updated theme, it should look like it is now (ensach.de)
I only wanted to update the theme, and everything is gone (slider, front page settings etc). Tried to rebuild it now, but i cannot like it was. Also the updated theme folder i uploaded via FTP is "colorway" and the old folder is called "colorwaytheme"...? So everything is gone...or have i bought the wrong theme? then i will give it back.
Hello, Greeting from InkThemes, I am attaching the links below for the videos. Kindly have a look to the attached links, they will help you. https://screenpresso.com/=ntXng https://screenpresso.com/=mDVO https://screenpresso.com/=F9Abb I hope these will help you if you need further help then just let us know, we will be ready to help you. Regards, Akbar InkThemes.com
Hi Akbar, thanks for your reply. As I wrote - i fixed the homepage set up problem. The Videos don´t help, because i dont want to import a demo, just wanted to set up a homepage. For all who have the same Problem: Just create a new page and select in "templates" --> homepage. Then you have a page which can be displayed, and all the customizations from the Customizer can take effect. QUESTION @ INKTHEMES: Before the update, we had 3 slides in the homepage slider. Now i can set up only 2. Can you give me some Custom CSS to expand the home slider to 3 slides? Or a hint to do this? Thanks, Regards,
Next issue :-((( Cannot set up the primary widget area...in customizer everything is fine and displayed - but not at the live page... Cannot set up via "Widgets" and not via "Customizer"...and these two don´t relate to each other Can you help please asap?
Hello, Greeting from InkThemes, The newest version of the theme comes with 2 sliders as the new version is Elementor based. The older pro version had 5 sliders in it and is based on theme options so if you want that we can add that in your account and you can use it. It is similar to the customizer panel as you can edit the home page content from the theme options. So just let us know we will do the needful for you. Regards, Akbar InkThemes.com
