Front page
Discussion in 'Traffica WordPress Theme' started by ewingd, Dec 21, 2014.
  1. ewingd
    ewingd New Member
    Hi can you tell me how to remove the section at the bottom of the home page which includes "contact us", "Our Pages, "search anything" and 'Inktheme themes" - i am using wordpress 4.1.
    thanks in advance for your help
  2. Pramod
    Pramod Guest
    For this you have to use text widget.They are by-default widgets on footer.
    Appearance =>widgets =>
    If you don't want use any widget at footer then use text widget.
    drag a text widget and drop on all 4 footer widget areas and do not fill any headings or text on widget.
    Pramod
  3. ewingd
    ewingd New Member
    great i'll give it a go! - thanks Pramod.
    D
