Full post on homepage
Discussion in 'Foogo Pro WordPress Theme' started by hitechpanda, Sep 17, 2015.
  1. hitechpanda
    hitechpanda Member
    How to display blog post as full content in homepage?
    I couldn't see frontpage.php as in other themes.
    You will get that file in which you have to edite in "inc" file instead of "front.php".
    Here I am providing you a screenshot below, you just have to follow the steps as mentioned over there.
    Hope it will resolve your issue:)
  3. hitechpanda
    hitechpanda Member
    Thanks. That worked, but the paragraph doesn't aligned properly now. Thoughts?
    Could you please provide us "URL" of your site with some edited screenshot so that we can assist you accordingly?
  5. hitechpanda
    hitechpanda Member
  6. priya
    We have checked your provided link and all paragraphs look properly aligned...
    Here's the screenshot, please have a look..
  7. hitechpanda
    hitechpanda Member
    Hi Priya,
    It's well aligned on the single post page, but not on the homepage as attached here: http://prntscr.com/8m8bmx
    Can you please double check?
  8. priya
    I am so sorry, but believe me I am just unable to figure out your issue as per your provided screenshot at my end...
    Here's the another screenshot of your site homepage, please have a look....
  9. hitechpanda
    hitechpanda Member
    Hi Priya,
    Sorry about that. Must be the cache plugin that's messing around. Can you try to have a look again? I've disabled the cache plugin so it should looks normal now. Also, can we set this thread as private? Honestly, I'm reluctant to show screenshots of real site for public so...
  10. priya
    Could you please send us your dashboard details at [email protected] so that we can figure out the issue and able to resolve that?
  11. hitechpanda
    hitechpanda Member
    Hi Priya,
    I've sent email as requested. Hope the team can resolve it.
  12. priya
    You would be glad to know that we have resolved your issue..:)
    Kindly check and reply..
  13. hitechpanda
    hitechpanda Member
    Hi Priya,
    Yes. Got it resolved. Thank you for the awesome response. Have a great weekend for all crew.
    Best,
