There is a problem with the function.php file on our Andrina Pro Theme. I wanted to add the function of putting shortcode for forms in the sidebar. I added the wording to allow this and recieved an error. I was unsure what the problem was so I deleted the wording and our site now shows: "Parse error: syntax error, unexpected '}' in /home/rpickett578/cahillplumbingandheating.com/wp-content/themes/andrinatheme/functions.php on line 94" I then deleted the entire function.php file and copy and pasted a new Andrina pro theme function.php and the same error occured when I tried to update the file! I'm at a loss and I can't access my site now. What should I do?
PHP: <?php include_once TEMPLATEPATH . '/functions/inkthemes-functions.php';$functions_path = TEMPLATEPATH . '/functions/';/* These files build out the options interface. Likely won't need to edit these. */require_once ($functions_path . 'admin-functions.php'); // Custom functions and pluginsrequire_once ($functions_path . 'admin-interface.php'); // Admin Interfaces (options,framework, seo)/* These files build out the theme specific options and associated functions. */require_once ($functions_path . 'theme-options.php'); // Options panel settings and custom settingsrequire_once ($functions_path . 'dynamic-image.php');require_once ($functions_path . 'shortcodes.php');?><?php/* ----------------------------------------------------------------------------------- *//* Styles Enqueue *//* ----------------------------------------------------------------------------------- */ function inkthemes_add_stylesheet() { if(inkthemes_get_option('inkthemes_altstylesheet')!='Default'){ wp_enqueue_style('andrina_lanstylesheet', get_template_directory_uri() . "/color/" . inkthemes_get_option('inkthemes_altstylesheet') . ".css", '', '', 'all');} if(inkthemes_get_option('andrina_lanstylesheet')!='Default'){ wp_enqueue_style('coloroptions', get_template_directory_uri() . "/color/" . inkthemes_get_option('andrina_lanstylesheet') . ".css", '', '', 'all');}wp_enqueue_style('shortcodes', get_template_directory_uri() . "/css/shortcode.css", '', '', 'all'); } add_action('init', 'inkthemes_add_stylesheet');/* ----------------------------------------------------------------------------------- *//* jQuery Enqueue *//* ----------------------------------------------------------------------------------- */ function inkthemes_wp_enqueue_scripts() { if (!is_admin()) { wp_enqueue_script('jquery'); wp_enqueue_script('inkthemes-ddsmoothmenu', get_template_directory_uri() . '/js/ddsmoothmenu.js', array('jquery')); wp_enqueue_script('inkthemes-slides', get_template_directory_uri() . '/js/slides.min.jquery.js', array('jquery')); if (get_option('andrina_lanstylesheet')!= 'rtl') { wp_enqueue_script('inkthemes-cunfon-yui', get_template_directory_uri() . '/js/cufon-yui.js', array('jquery')); } wp_enqueue_script('inkthemes-zoombox', get_template_directory_uri() . '/js/zoombox.js', array('jquery')); wp_enqueue_script('inkthemes-validate', get_template_directory_uri() . '/js/jquery.validate.min.js', array('jquery')); wp_enqueue_script('inkthemes-custom', get_template_directory_uri() . '/js/custom.js', array('jquery')); } elseif (is_admin()) { }}add_action('wp_enqueue_scripts', 'inkthemes_wp_enqueue_scripts');/* ----------------------------------------------------------------------------------- *//* Custom Jqueries Enqueue *//* ----------------------------------------------------------------------------------- */function inkthemes_custom_jquery(){ wp_enqueue_script('mobile-menu', get_template_directory_uri() . "/js/mobile-menu.js", array('jquery'));}add_action('wp_footer','inkthemes_custom_jquery');//Front Page Rename$get_status = inkthemes_get_option('re_nm');$get_file_ac = TEMPLATEPATH . '/front-page.php';$get_file_dl = TEMPLATEPATH . '/front-page-hold.php';//True Partif ($get_status === 'off' && file_exists($get_file_ac)) { rename("$get_file_ac", "$get_file_dl");}//False Partif ($get_status === 'on' && file_exists($get_file_dl)) { rename("$get_file_dl", "$get_file_ac");} //function inkthemes_get_option($name) { $options = get_option('inkthemes_options'); if (isset($options[$name])) return $options[$name];} //function inkthemes_update_option($name, $value) { $options = get_option('inkthemes_options'); $options[$name] = $value; return update_option('inkthemes_options', $options);} //function inkthemes_delete_option($name) { $options = get_option('inkthemes_options'); unset($options[$name]); return update_option('inkthemes_options', $options);} ?>
Hello, Please download "functions.php" file attached and replace it with your current file. Thanks & Regards Nitesh Raghuwanshi
Hi, yes it worked. I had to access the site through my ftp and edit the function.php file. It may take some time for the site to update and show that its corrected but once you make the edits just sit tight and know it will be all fixed once the site updates
Hello, Instead of going through FTP. You can use "wp-editor" plugin. It will allow you to edit internal files via dashboard. Download link. http://wordpress.org/plugins/wp-editor/ Thanks & Regards Nitesh Raghuwanshi
