Gallery problem - MarkJPhoto
Discussion in 'GoldenEagle WordPress Theme' started by markjphoto, Jan 15, 2013.
  1. markjphoto
    markjphoto New Member
    Northallerton, north Yorkshrie
    When i use the gallery template, my photos correctly go into a gallery however when you click on the photo it enlarges to a full page width with the photo in the left hand corner of the page, why is this?
  2. Harmeet
    Harmeet Support Staff
    Please share the link of your website.
  3. markjphoto
  4. Nitesh
    Follow process given below while uploading gallery images.
    1) Clicked on Add New Page
    2) Chose Template "Gallery Template"
    3) Chose "Add Media"
    4) Chose "Insert Media" >Upload Files >Select Files
    5) After selecting files just cut that window without clicking "Insert into page" button.
    6) Update page.
  5. markjphoto
    Thanks for this, i've tried it twice but it doesnt work as there are no photos that come up on the gallery page that way.
  6. Gourav
  7. markjphoto
    Thanks for this suggestion but as it's seems to be a flash plugin and really slow...is there any way to sort out why when you click on a photo in my gallery page http://mark-johnston-photography.co.uk/weddings-4/gallery-2 the photo shows in the full scrren with a large amount of white space? I just want to be able to click on the photo and it enlarge normally, thanks
  8. Nitesh
    The solution i have posted above is the only way to add images in themes gallery template. The way you are adding images will not fulfill what you want.
    Follow instructions below, They are in a more descriptive way and will help you.
  9. markjphoto
    Thanks this has worked, sorry I was being awkward!
