GC 1.8 multi-check box & radiobuttons
Discussion in 'GeoCraft WordPress Theme' started by hoit, Sep 28, 2013.
  1. hoit
    hoit Member
    I have upgrade to GeoCraft 1.8. The Multi-check-boxes is a very nice featured:)
    However I have a question: How to un-mark / re-set the radiobuttons or multi-check-boxes?
    If the customer, by mistake, clicks-on(mark) the radiobuttons or multi-check-boxes its seems not possible to undo.
    (My settings for the customfields are: enable for free listing, and not required)
    Thanks in advance
    Best regards /Kristina
    User can deselect check box by double click on selected box.
    To reset radio button user need to refresh listing submit page.
    Solution
    You can create an extra radio button which can be selected by user. If he don't want to select any other button.
  3. hoit
    hoit Member
    Hi, Nitesh, tanks for your answer.
    It seems to work fine from the dashboard but it doesn’t work from the wp-admin view
    Best regards/Kristina
