GeoCraft 1.6 with WordPress 3.5 Issue
Discussion in 'GeoCraft WordPress Theme' started by harsh5235, Dec 20, 2012.
  1. harsh5235
    harsh5235 Guest
  2. rogerb
    rogerb Active Member
    Exactly which button do you mean? Looked at your site and it all looks OK to me - i.e. looks like the standard site, I haven't created an account or gone that far!
  3. harsh5235
    harsh5235 Guest
    The Post button.....screenshot
  4. Nitesh
    Please check your site on other systems too, It is looking fine at our side.
    Please specify in any particular browser you are getting this issue or in all.
  5. harsh5235
    harsh5235 Guest
    Using Chrome. the issue only happens at certain zoom levels.
    if my browser zoom is set to 100%; issue does not happen.
    If it's set to 90% (like that screenshot) it does happen
  6. paulgc34
    paulgc34 New Member
    For a quick workaround you can paste the following CSS code in the Styling OPtions located under Geocraft Settings.
    The Code:
    .header_wrapper .header .post_btn .btn_left {display:none;}
    .header_wrapper .header .post_btn .btn_right {display:none;}
    .header_wrapper .header .post_btn .btn_center {background:transparent;background-color:#ff9900;border-radius:5px;}
    .header_wrapper .header .post_btn .btn_center:hover {background:transparent;background-color:#33cc00;border-radius:5px;}
    Screenshot of the fix
    Lines 3 and 4 have the button colors. Line 3 is the normal color state and line 4 is the color when the button is hoverd. You can change the color's to what ever you want. I used solid colors but you can use gradiant's with css if you want.
    manfred likes this.
