I'd like to have Classicraft as my main and then in a subfolder or subdomain, I'd like to have Geocraft. I can do that just fine but I want to have one login for both. Is that possible? If yes, how can I do it. That's the basic idea. The next one is to have a consolidated dashboard. That's a bit of stretch already but to be able to have shared login would be enough.
Hello, About shared "login" - Actually you could in some way do that... by using cookies and single-sign on plugin to achieve that. - You can also CLEF plugin see wordpress.org so user may have only one login info to used on as many site as s/he desires... but wit this one user needs a smartphone. - You can check premium.wpmudev.com there is a plugin called User Synchronization ($19) it does exactly what you are looking for. Hope this helps, - GM
