Geocraft Default Footer
Discussion in 'GeoCraft WordPress Theme' started by frontpage, Dec 28, 2013.
  1. frontpage
    frontpage Member
    Quick question...
    I see that the GeoCraft theme comes with some default content in the footer area. It appears as though these areas are controlled by widgets, however the 4 footer area widgets do not contain content currently, yet this default information still appears. If my client does not want content in the footer area at all, how can I disable the default content that comes with the theme? I tried adding content to all 4 widget areas and then deleting the content, but the default data re-appears.
    I am talking about the 4 footer widget areas, not the copyright footer information.
    Thanks.
    Go to the
    Appearance > Widgets
    Drag "Text" widgets and add paragraph tag in it and drop them in the first, second, third and fourth widget area.
    <p></p>
    Gourav Shrivastava
